Expanding the tree inside the Method Browser is causing a rhino crash.
Work In Progress
(6.0.17116.6371, 26/04/2017)
Windows 10
Work In Progress
Windows 10
Hi Bogdan,
Sorry but weâve been unable to reproduce the crash youâve reported. Can you repeat this? If so, can we get step-by-step instructions?
â Dale
Hi Dale,
I can replicate this. I just start Rhino, run EditPythonScript, than expand rhinoscriptsyntax and than, for example, application. I will see a Loading text and than i get the Rhino WIP has stopped working error.
I thought it might be a conflict between Rhino5 and 6 if they are both open but I tested and it seems not to be the case.
The problem persists even if i restart the computer.
What else do you suggest I should test?
Iâve tried to make this happen as well, and I cannot⌠seems fine here. @dale - is it a video thing, do you think?
Do you have to have a specific script open when you do this or does it happen all of the time?
I also checked on another computer and it works fine.
The crash is happening on an Asus n552v, which has a GeForce GTX 960M.
This happens all the time without me opening any file or script.
Did you ever install IronPython on this computer?
No, I havenât.
This problem still persists.
I tested by running Rhino on intel integrated card and on nvida card. So it seems that it might not be a display issue?
Hi Bogdan,
When the crash occurs, are you presented with a dialog that asks you if you want to submit your crash information? does Rhino leave a âcrashâ or âdumpâ file on your desktop?
â Dale
No, I get only the Windows dialog âRhino WIP has stopped workingâ.
Hi, Iâm not sure if this is the same issue, but I am unable to open the Python Editor. When I select
Command: _EditPythonScript
I receive the message:
Error occured loading plug-in
Details:
Failed to load language 'IronPython 2.7.5': Method not found: 'Boolean Microsoft.Scripting.Utils.ReflectionUtils.IsInterface(System.Type)'.Unknown command: _EditPythonScript
Version: Rhino 6 SR0 2017-6-6 (Rhino WIP, 6.0.17157.8191
Welp, Steve solved my problem. I had an additional install of IronPython to my computer. Uninstalling that solved the issue
Yes, I solved this by uninstalling IronPython with Add/Remove programs.
