Creating Void within a curved wall
I’m sort of a newbie when it comes to grasshopper but I have been recently diving deeper into it and trying to gain a better understanding especially with it’s integration with Rhino inside of Revit. I’m currently working on a project for school and I need some assistance with subtracting a hole based off a curve and having it translate into Revit.
I included both the rhino and grasshopper script, I baked in the wall to give a better understanding of how I want to form the shape.
Any help would be greatly appreciated!
Screenshot 2023-10-16 103600
Facade_Studio.3dm (8.0 MB)
STUDIO_UPDATED_Grasshopper_curved.gh (79.3 KB)
Hi Ethan, Here is something similar to what you are doing.
Thank you for the response. I was wondering if there was a way to convert a brep into a revit wall. I have sort of given up because I think most of my curves are too complex to actually create the void so instead is it possible to create a wall out of a brep? If so I would manually create all of the window openings and than just translate it back into revit
Your geometry sort of comes in as a DirectShape in the Wall category.
When bringing in Geometry to Revit it needs to conform to the Revit geometry tolerances.
https://www.rhino3d.com/inside/revit/1.0/guides/rir-grasshopper#tolerances
We attempt to import as much as possible, the smaller of the two breps isn’t getting closed.
I was using the circles and what not as a facade so I’m fine leaving them as a DirectShape, I was wondering if it’d be possible to turn this closed poly surface for example into a revit wall so I could just add a window and what not.
Currently using this wall as an example because I know it’s going to give me the most issues.
DirectShape is going to be the way to go. Revit isn’t conducive for that type of geometry in its native walls / windows.
You can create a Native Revit wall by Curve or by Profile.
