Python: 4D Spiral formula problem
Does someone know what I am doing wrong?
When I try to change my radius r-value it shortens the spiral.
20230419PointDistribution.gh (18.3 KB)
Are you trying to implement the top Stack Overflow answer? It’s pretty neat:
230419_FiboSphere_00.gh (4.1 KB)
I think I put this as a spiral components in Nautilus plugin
Oops I needed to insert the right link, I mean a hyperspiral like hyper and then spiral
hyperspiral
NAUTILUS plugin from Laurent Delrieu
What an amazing plugin you made, fantastic, great! Everyone should buy it! Such an amazing plugin. I like the NAUTILUS plugin so much! I see you can do MORE with it!
If you are a student and your university allows you to the educational version of rhino/grasshopper you can download the NAUTILUS plugin 4real on Nautilus | Food4Rhino
Hey, I aso try to code it in Python
Do you know want I do wrong with my radius r-value :slight_smile:
hyperspiral
It is implementing this code for a hyperspiral
In the code on the right there are things like j-- and as2
Somehow it is possible to let i0 eventually become equal to i but when and where I do not understand. as2? actionscript2?
I took the code and put it in C#. I made the whole class not just the method. It is easier to understand first in 2D and 3D than directly using 4D. Secondly I think you didn’t use the method as(i0, i1, i2, i3).
But I am not a Python guy, I don’t want to dive into your code. I saw too much programming languages in my life (Turbo Pascal, c++, Fortran 77, Fortran 90, Ada, Java, Matlab, Visual Basic, C#)
I didn’t go very far but the code is not outputting sphere position but it outputs a spiral points.
In 2D
in 3d
in 4D
ptn has the positions of the points
in 2D Point3(ptn[i], ptn[i+1],0)
in 3D Point3(ptn[i], ptn[i+1],ptn[i+2])
in 4D if w0 Point3(ptn[i], ptn[i+1],ptn[i+2]) ptn[i+3] not used
Representation with 4dim as a color
