Hey All,
Well, of course just before a project is due you run into problems, right?! So I am trying to render a very simple file, I’ve actually even tried this on other files, where I just had a block or cylinder displayed, and I am having the same issue with Rhino 6 ProRender. When I change display mode to any choice besides ProRender I have no problem. Even when using Raytraced (cycles) my computer hums along and generates an image. But, if I switch to ProRender, I get the note at the bottom of the viewport “ProRender Rendering…”. I can hear my computer working hard but the screen is not changing to a ProRendered image. If I try to change the display mode to something else now, like “Artic” nothing happens. The computer continues to strain away. If I click anywhere in the UI I get the message at the top of Rhino saying “Not Responding”. Then I need to force close the app.
In actually rendering images, I find the same thing happening. if I set the current renderer to Rhino Render, I’m able to get a scene to render out as usual. All controls like Resolution, View etc all work. But, If I select ProRender as the current renderer and click on “render” the render screen comes up and at the bottom I see the message “Rendering Frame 0/128 0%” and the render never starts.
I’ve tried reinstalling the program, changing settings for Cycles like: device settings from CPU to CUDA, and changed throttling from 20 to 50ms and samples from 500 down to 200, but no change. ProRender still locks up.
Below is my system info. Has anyone else had this issue? Thanks:
Rhino 6 SR8 2018-8-28 (Rhino 6, 6.8.18240.20051, Git hash:master @ d037927543424e8b3ce54e46b435866178a6349c)
Licence type: Commercial, build 2018-08-28
License details: Cloud Zoo. In use by: j.w. ()
Windows 10.0 SR0.0 or greater (Physical RAM: 16Gb)
Machine name: XXXXXXXXX
GeForce GPU/PCIe/SSE2 (OpenGL ver:4.6.0 NVIDIA 399.07)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 8-21-2018
Driver Version: 24.21.13.9907
Z-Buffer depth: 24 bits
Total Video Memory: 1 GB
C:\Program Files\Rhino 6\Plug-ins\Commands.rhp “Commands” 6.8.18240.20051
C:\Program Files\Rhino 6\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 6\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Common Files\McNeel\Rhinoceros\6.0\Plug-ins\ProRender (2aae3eb3-985b-4e64-b19a-fed69ef9dfeb)\2017.11.6.756\ProRender.rhp “ProRender”
C:\Program Files\Rhino 6\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 6\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 6.8.18240.20051
C:\Program Files\Rhino 6\Plug-ins\Alerter.rhp “Alerter”
C:\Program Files\Rhino 6\Plug-ins\RhinoCycles.rhp “RhinoCycles” 6.8.18240.20051
C:\Program Files\Rhino 6\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 6.8.18240.20051
