AMD ProRender crashes when the scene is populated
Tried AMD ProRender and started to like it. However, once I populated the scene with dozens of objects, ProRender.crashed most of the time. I then tried to use Rhino Cycles, and it ran without issue.
Anyone experiencing similar issue?
@Joshua_Kennedy you might want to look into this (:
Really appreciate for the tag, @nathanletwory :smiling_face:
Can you send the model so I can attempt to reproduce this? It can be done confidentially here
https://www.rhino3d.com/upload?to=joshua@mcneel.com
Really appreciate it, @Joshua_Kennedy . Will do it accordingly :smiling_face:
I am experiencing the same issue. Is there any fix :slight_smile:
I just published version 1.0.1.5 of ProRender to the PackageManager. Please update and let know if that resolves the issue.
Hi Joshua.
Thank you so much for the notice.
I had tested it using:
Core i9 12900H
RTX 3050i, 3070, A4000 and A5000
I encountered random crashes and still trying to figure out what’s causing it.
Really appreciate the effort, Joshua. I hope to see ProRender to work nice alongside Cycles.
