System info posted below.
I cannot get this render to start. Nothing major has changed in my workflow, although the complexity of this project is somewhat bigger than others in the past. I work typically in a series of nested block instances on an Intel Macbook Pro running cycles off of the CPU. Cannot figure out what I am doing differently that would cause Rhino to not respond and crash. Its been several days of trying to get a render to start, and after reading up on several posts regarding rendering Rhino7 on Intel machines I still haven’t found a way to solve this problem- I have been able to render before.
I’ve tried:
*Begining render with the viewport in Wireframe to save response time.
- Managing storage on the mac to free up flash storage. I have 389 GB available on a 1T HD.
*Resetting Render Settings to default and re-entering desired effects.
*Removed transparent background and ground plane options (the combination of transparent background and ground plane: shadows only takes a lot of processing power and has caused crashes in the past)
*Exploding block instances to polysurfaces (Increase file size from ~150MB to 550MB)
*Reducing Session samples to 50 and overriding production render quality
*Reduce render Quality
*Toggled different combinations of Dithering and Gamma on/off
Currently at a loss as to what to try next. I’m ordering a few more hard drives to back up all the clients data separately from this machine and trying to free up as much space as possible.
Rhino 7 SR33 2023-8-1 (Rhino 7, 7.33.23213.13002, Git hash:master @ beed91711342a1d84e696dc6725c3bf7d407dce0)
License type: Commercial, build 2023-08-01
License details: Cloud Zoo
Apple macOS Version 12.6.6 (Build 21G646) (Physical RAM: 64Gb)
Mac Model Identifier: MacBookPro16,1
Language: en-US (MacOS default)
AMD Radeon Pro 5500M OpenGL Engine (OpenGL ver:4.1 ATI-4.8.101)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.1
Shading Language: 4.10
Z-Buffer depth: n/a
Total Video Memory: 8176 MB
Graphics: AMD Radeon Pro 5500M
Displays: Color LCD (264dpi 2x)
Graphics processors
Intel UHD Graphics 630 (1536 MB)
AMD Radeon Pro 5500M (8 GB)
Color LCD (1792 x 1120 @ 59.00Hz)
USB devices
Apple: composite_device
Apple Inc.: Touch Bar Backlight
Apple Inc.: Touch Bar Display
Apple Inc.: Apple Internal Keyboard / Trackpad
Apple: Headset
Apple Inc.: Ambient Light Sensor
Apple Inc.: FaceTime HD Camera (Built-in)
Apple Inc.: Apple T2 Controller
Bluetooth devices
None
Third party kernel extensions
None
Third party plugins
/Library/Frameworks/3DconnexionClient.framework/Versions/A/3DconnexionClient
/usr/lib/swift/libswiftCloudKit.dylib
/usr/lib/swift/libswiftCoreData.dylib
/usr/lib/swift/libswiftFoundation.dylib
/usr/lib/swift/libswiftAppKit.dylib
/usr/lib/swift/libswiftContacts.dylib
/usr/lib/swift/libswiftCoreML.dylib
/usr/lib/swift/libswiftVision.dylib
/usr/lib/swift/libswiftNetwork.dylib
/usr/lib/swift/libswiftFileProvider.dylib
/usr/lib/swift/libswiftPrivate_BiomePubSub.dylib
/usr/lib/swift/libswiftPrivate_BiomeStreams.dylib
/Users/diomira/Library/Application Support/McNeel/Rhinoceros/packages/7.0/IntelDenoiser/0.6.4/libtbb.dylib
/Users/diomira/Library/Application Support/McNeel/Rhinoceros/packages/7.0/IntelDenoiser/0.6.4/libtbbmalloc.dylib
/Users/diomira/Library/Application Support/McNeel/Rhinoceros/packages/7.0/IntelDenoiser/0.6.4/IntelDenoiser.Mac.rhp “IntelDenoiser.Mac” 1.0.0.0
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRenderCycles.rhp “Rhino Render” 7.33.23213.13002
/Applications/Rhino 7.app/Contents/PlugIns/RhinoBonusTools.rhp “Rhino Bonus Tools” 7.33.23213.1002
/Applications/Rhino 7.app/Contents/PlugIns/NamedPositions.rhp “Named Position” 7.33.23213.1002
/Applications/Rhino 7.app/Contents/PlugIns/PanelingTools.rhp “PanelingTools” 7.33.23213.1002
/Applications/Rhino 7.app/Contents/PlugIns/AnimationTools.rhp “AnimationTools” 7.33.23213.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp “IronPython” 7.33.23213.13002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp “Commands” 7.33.23213.13002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp “Grasshopper” 7.33.23213.13002
/Applications/Rhino 7.app/Contents/PlugIns/Displacement.rhp “Displacement” 7.33.23213.1002
/Applications/Rhino 7.app/Contents/PlugIns/RhinoRender.rhp “Legacy Rhino Render” 7.33.23213.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp “RDK_EtoUI” 7.33.23213.13002
/Applications/Rhino 7.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp “RhinoCycles” 7.33.23213.13002
/Applications/Rhino 7.app/Contents/PlugIns/NamedSnapshots.rhp “Snapshots” 7.33.23213.1002
/Applications/Rhino 7.app/Contents/Frameworks/RhMaterialEditor.framework “Renderer Development Kit” 7.33.23213.1002
