Problems with Hops and ghhops_server
Hi everyone, I used Hops on my laptop to connect Grasshopper with external Python codes to use all the libraries I need. I’m now reinstalling everything on my new laptop (Windows 11, Python 3.11.1, Rhino 7) but when I try to install ghhhops_server it gives me these errors:
Installing collected packages: rhino3dm, ghhops_server
DEPRECATION: rhino3dm is being installed using the legacy ‘setup.py install’ method, because it does not have a ‘pyproject.toml’ and the ‘wheel’ package is not installed. pip 23.1 will enforce this behaviour change. A possible replacement is to enable the ‘–use-pep517’ option. Discussion can be found at https://github.com/pypa/pip/issues/8559
Running setup.py install for rhino3dm … error
error: subprocess-exited-with-error
× Running setup.py install for rhino3dm did not run successfully.
│ exit code: 1
╰─> [82 lines of output]
running install
C:\Program Files\Python311\Lib\site-packages\setuptools\command\install.py:34: SetuptoolsDeprecationWarning: setup.py install is deprecated. Use build and pip and other standards-based tools.
warnings.warn(
running build
running build_py
creating build
creating build\lib.win-amd64-cpython-311
creating build\lib.win-amd64-cpython-311\rhino3dm
copying src\rhino3dm_init_.py → build\lib.win-amd64-cpython-311\rhino3dm
running egg_info
writing src\rhino3dm.egg-info\PKG-INFO
writing dependency_links to src\rhino3dm.egg-info\dependency_links.txt
writing top-level names to src\rhino3dm.egg-info\top_level.txt
reading manifest file ‘src\rhino3dm.egg-info\SOURCES.txt’
reading manifest template ‘MANIFEST.in’
warning: no files found matching ‘.pyd’ under directory ‘src\rhino3dm’
warning: no files found matching '
.so’ under directory ‘src\rhino3dm’
adding license file ‘LICENSE’
writing manifest file ‘src\rhino3dm.egg-info\SOURCES.txt’
copying src\rhino3dm_init_.pyi → build\lib.win-amd64-cpython-311\rhino3dm
copying src\rhino3dm\py.typed → build\lib.win-amd64-cpython-311\rhino3dm
running build_ext
Traceback (most recent call last):
File “C:\Users\franc\AppData\Local\Temp\pip-install-qii0jzp6\rhino3dm_b2d3d3d480db4777b3465bc5f183da00\setup.py”, line 32, in run
out = subprocess.check_output([‘cmake’, ‘–version’])
File “C:\Program Files\Python311\Lib\subprocess.py”, line 466, in check_output
return run(*popenargs, stdout=PIPE, timeout=timeout, check=True,
File “C:\Program Files\Python311\Lib\subprocess.py”, line 548, in run
with Popen(*popenargs, **kwargs) as process:
File “C:\Program Files\Python311\Lib\subprocess.py”, line 1024, in init
self._execute_child(args, executable, preexec_fn, close_fds,
File “C:\Program Files\Python311\Lib\subprocess.py”, line 1493, in _execute_child
hp, ht, pid, tid = _winapi.CreateProcess(executable, args,
FileNotFoundError: [WinError 2] Impossibile trovare il file specificato
  During handling of the above exception, another exception occurred:
    File "<string>", line 2, in <module>
    File "<pip-setuptools-caller>", line 34, in <module>
    File "C:\Users\franc\AppData\Local\Temp\pip-install-qii0jzp6\rhino3dm_b2d3d3d480db4777b3465bc5f183da00\setup.py", line 111, in <module>
      setup(
    File "C:\Program Files\Python311\Lib\site-packages\setuptools\__init__.py", line 87, in setup
      return distutils.core.setup(**attrs)
    File "C:\Program Files\Python311\Lib\site-packages\setuptools\_distutils\core.py", line 185, in setup
      return run_commands(dist)
    File "C:\Program Files\Python311\Lib\site-packages\setuptools\_distutils\core.py", line 201, in run_commands
      dist.run_commands()
    File "C:\Program Files\Python311\Lib\site-packages\setuptools\_distutils\dist.py", line 968, in run_commands
      self.run_command(cmd)
    File "C:\Program Files\Python311\Lib\site-packages\setuptools\dist.py", line 1217, in run_command
      super().run_command(command)
    File "C:\Program Files\Python311\Lib\site-packages\setuptools\_distutils\dist.py", line 987, in run_command
      cmd_obj.run()
    File "C:\Program Files\Python311\Lib\site-packages\setuptools\command\install.py", line 68, in run
      return orig.install.run(self)
    File "C:\Program Files\Python311\Lib\site-packages\setuptools\_distutils\command\install.py", line 698, in run
      self.run_command('build')
    File "C:\Program Files\Python311\Lib\site-packages\setuptools\_distutils\cmd.py", line 319, in run_command
      self.distribution.run_command(command)
      cmd_obj.run()
    File "C:\Program Files\Python311\Lib\site-packages\setuptools\_distutils\command\build.py", line 132, in run
      self.run_command(cmd_name)
      cmd_obj.run()
    File "C:\Users\franc\AppData\Local\Temp\pip-install-qii0jzp6\rhino3dm_b2d3d3d480db4777b3465bc5f183da00\setup.py", line 34, in run
      raise RuntimeError(
  RuntimeError: CMake must be installed to build the following extensions: rhino3dm._rhino3dm
  [end of output]
note: This error originates from a subprocess, and is likely not a problem with pip.
error: legacy-install-failure
× Encountered error while trying to install package.
╰─> rhino3dm
note: This is an issue with the package mentioned above, not pip.
hint: See above for output from the failure.
How can I fix it?
Thank you in advance
same to me, much appreciate it if anybody can help…
ghhops-server does not currently support CPython 3.11. You will need to use CPython 3.10
My suggestion is that you use anconda and create the new environment, install visual code e on this, open from Anconda, and type “pip install ghhops_server==1.5.1” at the command prompt
