FYI, the ghhops-server package on PyPi does not install correctly on python3.13
calling pip install ghhops-server
results in the error:
Collecting ghhops-server
Using cached ghhops_server-1.5.5-py2.py3-none-any.whl.metadata (317 bytes)
Collecting rhino3dm (from ghhops-server)
Using cached rhino3dm-8.9.0.tar.gz (66.0 MB)
Installing build dependencies ... done
Getting requirements to build wheel ... done
Preparing metadata (pyproject.toml) ... done
Using cached ghhops_server-1.5.5-py2.py3-none-any.whl (11 kB)
Building wheels for collected packages: rhino3dm
Building wheel for rhino3dm (pyproject.toml) ... error
error: subprocess-exited-with-error
× Building wheel for rhino3dm (pyproject.toml) did not run successfully.
│ exit code: 1
╰─> [122 lines of output]
Using Python executable: /Library/Frameworks/Python.framework/Versions/3.13/bin/python3.13
running bdist_wheel
running build
running build_py
creating build/lib.macosx-10.13-universal2-cpython-313/rhino3dm
copying src/rhino3dm/__init__.py -> build/lib.macosx-10.13-universal2-cpython-313/rhino3dm
running egg_info
writing src/rhino3dm.egg-info/PKG-INFO
writing dependency_links to src/rhino3dm.egg-info/dependency_links.txt
writing top-level names to src/rhino3dm.egg-info/top_level.txt
reading manifest file 'src/rhino3dm.egg-info/SOURCES.txt'
reading manifest template 'MANIFEST.in'
warning: no files found matching '*.pyd' under directory 'src/rhino3dm'
warning: no files found matching '*.so' under directory 'src/rhino3dm'
adding license file 'LICENSE'
writing manifest file 'src/rhino3dm.egg-info/SOURCES.txt'
copying src/rhino3dm/__init__.pyi -> build/lib.macosx-10.13-universal2-cpython-313/rhino3dm
copying src/rhino3dm/py.typed -> build/lib.macosx-10.13-universal2-cpython-313/rhino3dm
running build_ext
Traceback (most recent call last):
File "<string>", line 42, in run
File "/Library/Frameworks/Python.framework/Versions/3.13/lib/python3.13/subprocess.py", line 472, in check_output
return run(*popenargs, stdout=PIPE, timeout=timeout, check=True,
**kwargs).stdout
File "/Library/Frameworks/Python.framework/Versions/3.13/lib/python3.13/subprocess.py", line 554, in run
with Popen(*popenargs, **kwargs) as process:
File "/Library/Frameworks/Python.framework/Versions/3.13/lib/python3.13/subprocess.py", line 1036, in __init__
self._execute_child(args, executable, preexec_fn, close_fds,
pass_fds, cwd, env,
...<5 lines>...
gid, gids, uid, umask,
start_new_session, process_group)
File "/Library/Frameworks/Python.framework/Versions/3.13/lib/python3.13/subprocess.py", line 1966, in _execute_child
raise child_exception_type(errno_num, err_msg, err_filename)
FileNotFoundError: [Errno 2] No such file or directory: 'cmake'
During handling of the above exception, another exception occurred:
File "/Users/em/Desktop/untitled folder/venv/lib/python3.13/site-packages/pip/_vendor/pyproject_hooks/_in_process/_in_process.py", line 353, in <module>
main()
File "/Users/em/Desktop/untitled folder/venv/lib/python3.13/site-packages/pip/_vendor/pyproject_hooks/_in_process/_in_process.py", line 335, in main
json_out['return_val'] = hook(**hook_input['kwargs'])
File "/Users/em/Desktop/untitled folder/venv/lib/python3.13/site-packages/pip/_vendor/pyproject_hooks/_in_process/_in_process.py", line 251, in build_wheel
return _build_backend().build_wheel(wheel_directory, config_settings,
metadata_directory)
File "/private/var/folders/vm/mfby2rkn0g153d2tph6hz8r00000gn/T/pip-build-env-sl4qhbn3/overlay/lib/python3.13/site-packages/setuptools/build_meta.py", line 434, in build_wheel
return _build(['bdist_wheel', '--dist-info-dir', metadata_directory])
File "/private/var/folders/vm/mfby2rkn0g153d2tph6hz8r00000gn/T/pip-build-env-sl4qhbn3/overlay/lib/python3.13/site-packages/setuptools/build_meta.py", line 422, in _build
return self._build_with_temp_dir(
cmd,
...<3 lines>...
self._arbitrary_args(config_settings),
File "/private/var/folders/vm/mfby2rkn0g153d2tph6hz8r00000gn/T/pip-build-env-sl4qhbn3/overlay/lib/python3.13/site-packages/setuptools/build_meta.py", line 403, in _build_with_temp_dir
self.run_setup()
File "/private/var/folders/vm/mfby2rkn0g153d2tph6hz8r00000gn/T/pip-build-env-sl4qhbn3/overlay/lib/python3.13/site-packages/setuptools/build_meta.py", line 516, in run_setup
super().run_setup(setup_script=setup_script)
File "/private/var/folders/vm/mfby2rkn0g153d2tph6hz8r00000gn/T/pip-build-env-sl4qhbn3/overlay/lib/python3.13/site-packages/setuptools/build_meta.py", line 318, in run_setup
exec(code, locals())
File "<string>", line 143, in <module>
File "/private/var/folders/vm/mfby2rkn0g153d2tph6hz8r00000gn/T/pip-build-env-sl4qhbn3/overlay/lib/python3.13/site-packages/setuptools/__init__.py", line 117, in setup
return distutils.core.setup(**attrs)
File "/private/var/folders/vm/mfby2rkn0g153d2tph6hz8r00000gn/T/pip-build-env-sl4qhbn3/overlay/lib/python3.13/site-packages/setuptools/_distutils/core.py", line 183, in setup
return run_commands(dist)
File "/private/var/folders/vm/mfby2rkn0g153d2tph6hz8r00000gn/T/pip-build-env-sl4qhbn3/overlay/lib/python3.13/site-packages/setuptools/_distutils/core.py", line 199, in run_commands
dist.run_commands()
File "/private/var/folders/vm/mfby2rkn0g153d2tph6hz8r00000gn/T/pip-build-env-sl4qhbn3/overlay/lib/python3.13/site-packages/setuptools/_distutils/dist.py", line 954, in run_commands
self.run_command(cmd)
File "/private/var/folders/vm/mfby2rkn0g153d2tph6hz8r00000gn/T/pip-build-env-sl4qhbn3/overlay/lib/python3.13/site-packages/setuptools/dist.py", line 991, in run_command
super().run_command(command)
File "/private/var/folders/vm/mfby2rkn0g153d2tph6hz8r00000gn/T/pip-build-env-sl4qhbn3/overlay/lib/python3.13/site-packages/setuptools/_distutils/dist.py", line 973, in run_command
cmd_obj.run()
File "/private/var/folders/vm/mfby2rkn0g153d2tph6hz8r00000gn/T/pip-build-env-sl4qhbn3/overlay/lib/python3.13/site-packages/setuptools/command/bdist_wheel.py", line 407, in run
self.run_command("build")
File "/private/var/folders/vm/mfby2rkn0g153d2tph6hz8r00000gn/T/pip-build-env-sl4qhbn3/overlay/lib/python3.13/site-packages/setuptools/_distutils/cmd.py", line 316, in run_command
self.distribution.run_command(command)
cmd_obj.run()
File "/private/var/folders/vm/mfby2rkn0g153d2tph6hz8r00000gn/T/pip-build-env-sl4qhbn3/overlay/lib/python3.13/site-packages/setuptools/_distutils/command/build.py", line 135, in run
self.run_command(cmd_name)
cmd_obj.run()
File "<string>", line 44, in run
RuntimeError: CMake must be installed to build the following extensions: rhino3dm._rhino3dm
[end of output]
note: This error originates from a subprocess, and is likely not a problem with pip.
ERROR: Failed building wheel for rhino3dm
Failed to build rhino3dm
ERROR: ERROR: Failed to build installable wheels for some pyproject.toml based projects (rhino3dm)
Note that It does appear to work on python3 < .13
best,
@ed.p.may
