I can’t install ghhopes server… here is the error:
C:\>pip install ghhops-server
Collecting ghhops-server
Using cached ghhops_server-1.4.1-py2.py3-none-any.whl (10 kB)
Collecting rhino3dm
Using cached rhino3dm-7.7.0.tar.gz (5.5 MB)
Preparing metadata (setup.py) ... done
Building wheels for collected packages: rhino3dm
Building wheel for rhino3dm (setup.py) ... error
ERROR: Command errored out with exit status 1:
command: 'C:\Users\ARCHITECT\AppData\Local\Programs\Python\Python310\python.exe' -u -c 'import io, os, sys, setuptools, tokenize; sys.argv[0] = '"'"'C:\\Users\\ARCHITECT\\AppData\\Local\\Temp\\pip-install-z9gkioip\\rhino3dm_cc356ba01c324664bb7fb280f339c6ce\\setup.py'"'"'; __file__='"'"'C:\\Users\\ARCHITECT\\AppData\\Local\\Temp\\pip-install-z9gkioip\\rhino3dm_cc356ba01c324664bb7fb280f339c6ce\\setup.py'"'"';f = getattr(tokenize, '"'"'open'"'"', open)(__file__) if os.path.exists(__file__) else io.StringIO('"'"'from setuptools import setup; setup()'"'"');code = f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' bdist_wheel -d 'C:\Users\ARCHITECT\AppData\Local\Temp\pip-wheel-9d0rivra'
cwd: C:\Users\ARCHITECT\AppData\Local\Temp\pip-install-z9gkioip\rhino3dm_cc356ba01c324664bb7fb280f339c6ce\
Complete output (62 lines):
running bdist_wheel
running build
running build_py
creating build
creating build\lib.win-amd64-3.10
creating build\lib.win-amd64-3.10\rhino3dm
copying src\rhino3dm\__init__.py -> build\lib.win-amd64-3.10\rhino3dm
running egg_info
writing src\rhino3dm.egg-info\PKG-INFO
writing dependency_links to src\rhino3dm.egg-info\dependency_links.txt
writing top-level names to src\rhino3dm.egg-info\top_level.txt
reading manifest file 'src\rhino3dm.egg-info\SOURCES.txt'
reading manifest template 'MANIFEST.in'
warning: no files found matching '*.pyd' under directory 'src\rhino3dm'
warning: no files found matching '*.so' under directory 'src\rhino3dm'
adding license file 'LICENSE'
writing manifest file 'src\rhino3dm.egg-info\SOURCES.txt'
copying src\rhino3dm\__init__.pyi -> build\lib.win-amd64-3.10\rhino3dm
copying src\rhino3dm\py.typed -> build\lib.win-amd64-3.10\rhino3dm
running build_ext
Traceback (most recent call last):
File "C:\Users\ARCHITECT\AppData\Local\Temp\pip-install-z9gkioip\rhino3dm_cc356ba01c324664bb7fb280f339c6ce\setup.py", line 32, in run
out = subprocess.check_output(['cmake', '--version'])
File "C:\Users\ARCHITECT\AppData\Local\Programs\Python\Python310\lib\subprocess.py", line 420, in check_output
return run(*popenargs, stdout=PIPE, timeout=timeout, check=True,
File "C:\Users\ARCHITECT\AppData\Local\Programs\Python\Python310\lib\subprocess.py", line 501, in run
with Popen(*popenargs, **kwargs) as process:
File "C:\Users\ARCHITECT\AppData\Local\Programs\Python\Python310\lib\subprocess.py", line 966, in __init__
self._execute_child(args, executable, preexec_fn, close_fds,
File "C:\Users\ARCHITECT\AppData\Local\Programs\Python\Python310\lib\subprocess.py", line 1435, in _execute_child
hp, ht, pid, tid = _winapi.CreateProcess(executable, args,
FileNotFoundError: [WinError 2] The system cannot find the file specified
During handling of the above exception, another exception occurred:
File "<string>", line 1, in <module>
File "C:\Users\ARCHITECT\AppData\Local\Temp\pip-install-z9gkioip\rhino3dm_cc356ba01c324664bb7fb280f339c6ce\setup.py", line 111, in <module>
setup(
File "C:\Users\ARCHITECT\AppData\Local\Programs\Python\Python310\lib\site-packages\setuptools\__init__.py", line 153, in setup
return distutils.core.setup(**attrs)
File "C:\Users\ARCHITECT\AppData\Local\Programs\Python\Python310\lib\distutils\core.py", line 148, in setup
dist.run_commands()
File "C:\Users\ARCHITECT\AppData\Local\Programs\Python\Python310\lib\distutils\dist.py", line 966, in run_commands
self.run_command(cmd)
File "C:\Users\ARCHITECT\AppData\Local\Programs\Python\Python310\lib\distutils\dist.py", line 985, in run_command
cmd_obj.run()
File "C:\Users\ARCHITECT\AppData\Local\Programs\Python\Python310\lib\site-packages\wheel\bdist_wheel.py", line 299, in run
self.run_command('build')
File "C:\Users\ARCHITECT\AppData\Local\Programs\Python\Python310\lib\distutils\cmd.py", line 313, in run_command
self.distribution.run_command(command)
cmd_obj.run()
File "C:\Users\ARCHITECT\AppData\Local\Programs\Python\Python310\lib\distutils\command\build.py", line 135, in run
self.run_command(cmd_name)
cmd_obj.run()
File "C:\Users\ARCHITECT\AppData\Local\Temp\pip-install-z9gkioip\rhino3dm_cc356ba01c324664bb7fb280f339c6ce\setup.py", line 34, in run
raise RuntimeError(
RuntimeError: CMake must be installed to build the following extensions: rhino3dm._rhino3dm
ERROR: Failed building wheel for rhino3dm
Running setup.py clean for rhino3dm
Failed to build rhino3dm
Installing collected packages: rhino3dm, ghhops-server
Running setup.py install for rhino3dm ... error
command: 'C:\Users\ARCHITECT\AppData\Local\Programs\Python\Python310\python.exe' -u -c 'import io, os, sys, setuptools, tokenize; sys.argv[0] = '"'"'C:\\Users\\ARCHITECT\\AppData\\Local\\Temp\\pip-install-z9gkioip\\rhino3dm_cc356ba01c324664bb7fb280f339c6ce\\setup.py'"'"'; __file__='"'"'C:\\Users\\ARCHITECT\\AppData\\Local\\Temp\\pip-install-z9gkioip\\rhino3dm_cc356ba01c324664bb7fb280f339c6ce\\setup.py'"'"';f = getattr(tokenize, '"'"'open'"'"', open)(__file__) if os.path.exists(__file__) else io.StringIO('"'"'from setuptools import setup; setup()'"'"');code = f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' install --record 'C:\Users\ARCHITECT\AppData\Local\Temp\pip-record-8q374tlk\install-record.txt' --single-version-externally-managed --compile --install-headers 'C:\Users\ARCHITECT\AppData\Local\Programs\Python\Python310\Include\rhino3dm'
Complete output (64 lines):
running install
running build
running build_py
creating build
running egg_info
running build_ext
setup(
dist.run_commands()
cmd_obj.run()
File "C:\Users\ARCHITECT\AppData\Local\Programs\Python\Python310\lib\site-packages\setuptools\command\install.py", line 61, in run
return orig.install.run(self)
File "C:\Users\ARCHITECT\AppData\Local\Programs\Python\Python310\lib\distutils\command\install.py", line 568, in run
cmd_obj.run()
cmd_obj.run()
raise RuntimeError(
ERROR: Command errored out with exit status 1: 'C:\Users\ARCHITECT\AppData\Local\Programs\Python\Python310\python.exe' -u -c 'import io, os, sys, setuptools, tokenize; sys.argv[0] = '"'"'C:\\Users\\ARCHITECT\\AppData\\Local\\Temp\\pip-install-z9gkioip\\rhino3dm_cc356ba01c324664bb7fb280f339c6ce\\setup.py'"'"'; __file__='"'"'C:\\Users\\ARCHITECT\\AppData\\Local\\Temp\\pip-install-z9gkioip\\rhino3dm_cc356ba01c324664bb7fb280f339c6ce\\setup.py'"'"';f = getattr(tokenize, '"'"'open'"'"', open)(__file__) if os.path.exists(__file__) else io.StringIO('"'"'from setuptools import setup; setup()'"'"');code = f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' install --record 'C:\Users\ARCHITECT\AppData\Local\Temp\pip-record-8q374tlk\install-record.txt' --single-version-externally-managed --compile --install-headers 'C:\Users\ARCHITECT\AppData\Local\Programs\Python\Python310\Include\rhino3dm' Check the logs for full command output.
