Problem with quote scale in layout
test6 - Copia.3dm (1.3 MB)
Hello everyone, I have this file with 2 layouts, I’m using some dimensions and I got inconsistent results from print preview and the actual print, what am I doing wrong?
this is what I see from layout print preview
this is what I get
Hello @riccardo.foschi2 ,
Simply disable “layout scaling” in your annotation style.
For an in depth explanation :
but why in the first layout the scaling happens and in the second one it does not?, is there any documentation to understand what this option does? because I’m getting inconsistent results with that on.
I think it’s the perspective view that mess up the size from the preview and the actual print, in orthogonal view everything works properly
You’re right @riccardo.foschi2 .
The size of the print preview dialog window affect the scale the annotation size when layout space scaling is enable and in perspective view. (Resizing the dialog window we can clearly see the effect.)
There is no scaling when in orthogonal view or if layout space scaling is disable. This is weird.
After some digging, i’ve found this reported issue which is similar.
https://mcneel.myjetbrains.com/youtrack/issue/RH-77469
Best regards,
thanks for your effort, if it’s confirmed to be a bug I’ll report it right away!
