I have come across to a strange behavior while using Curve from 2 views.
As seen in the attached file I have two curves aligned on the Y axis and the same curves rotated.
Curve from 2 views works fine for the first set of curves but not on the rotated ones. Am I missing something or is this some bug that should be reported?
Hi Stef - since there are three curves in each setm it’s not clear which are the inputs - I cannot, so far, get the results you are getting. Can you please post just the two input curves for each?
