Problem with Curve Closest Point in Python 3
Hi guys,
I’ve noticed something odd with the Curve Closest Point in Python 3.
In the image below, there’s a simple example of a single point and a curve, with the same code executed in IronPython and Python 3. I used iTestPoint from Rhino and set the maximum distance to 5. However, the issue is that I get different Boolean values in the output. IronPython displays the correct result ‘False’, as the iTestPoint is not within the given range of 5.
Am I doing something wrong, or could this be a bug in Python 3?
This is a known issue that is logged here
Thanks for reporting
hei Alain
sorry, is this problem solved, because i still have it.
Hi. This fix will be in service release v. 8.5
