You’re welcome!
If your interested in a RhinoCommon version, it is done very similarly.
However, you might have to set your component inputs to curve and point inputs respectively, for it to work.
import Rhino.Geometry as rg
# Get the curve parameter
success, t = curve.ClosestPoint(point)
# Get the closest point on the curve to your point
crv_pt = curve.PointAt(t)
# Measure the distance between both points
dist = point.DistanceTo(crv_pt)
# Compare the distance to your tolerance
if dist <= tolerance:
print "Point was indeed within %.2f distance." %(tolerance)
a = True
else:
print "Point was not within %.2f distance." %(tolerance)
a = False
In RhinoCommon, as you may already know, you call the methods/functions differently.
Rhinoscriptsyntax is basically a “repackaged” Python API of RhinoCommon that makes the latter more straightforward to use.
In order to understand the structural differences between both, you need to understand, what namespaces, classes, constructors, methods/functions, etc. are in programming.
Here’s a simple example:
curve.ClosestPoint(point) calls the method ClosestPoint() from the Curves class that exists in the Rhino.Geometry namespace. Your variable curve is in fact an instance of the Curves class and ClosestPoint() one of its class methods.
Your variable point is an instance of the Point class from Rhino.Geometry that has its own class methods to chose from.
This is also, why you need to change the inputs of your component to curve and point inputs. I’m not totally sure about this, but I guess that when you declare the types of your inputs, the component passes class instances to your code, which is essential for RhinoCommon.
The rhinoscriptsyntax, on the other hand mostly works with guids, some type of geometry reference (?), an identification of sorts of geometry objects (?). Why it doesn’t need the type declarations on component input level, is because it mostly does the conversions internally (see below).
In rhinoscriptsyntax, you basically call the method CurveClosestPoint() from the rhinosciptsyntax library that you previously imported.
And, here’s what happens under the hood (cf. source):
def CurveClosestPoint(curve_id, test_point, segment_index=-1 ):
"""Returns parameter of the point on a curve that is closest to a test point.
Parameters:
curve_id (guid): identifier of a curve object
point (point): sampling point
segment_index (number, optional): curve segment index if `curve_id` identifies a polycurve
Returns:
number: The parameter of the closest point on the curve
Example:
id = rs.GetObject("Select a curve")
if id:
point = rs.GetPointOnCurve(id, "Pick a test point")
if point:
param = rs.CurveClosestPoint(id, point)
print "Curve parameter:", param
See Also:
EvaluateCurve
IsCurve
curve = rhutil.coercecurve(curve_id, segment_index, True)
point = rhutil.coerce3dpoint(test_point, True)
rc, t = curve.ClosestPoint(point, 0.0)
if not rc: raise Exception("ClosestPoint failed")
return t
First, the method converts its parameter curve_id, which is the guid of the passed-in curve, to an instance of the Curve class from Rhino.Geometry. The parameter test_point is converted to an instance of the Point class from Rhino.Geometry (?).
After that, the method simply calls the CurveClosestPoint() method, like I did in the RhinoCommon example above, from the instance of the Curve class, saved in the variable curve. Remember, the Curve class lives in the Rhino.Geometry namespace.
I’ve added a question marks between parenthesis to all the parts that I’m not 100% sure of.
