Hi All I am try to find the equivalent in C# for
Curve.ClosestPoint is giving me a different result to the node, when using the same points to test from.
Green (Node), Ref (Code)
Have I misunderstood the ClosestPoint method?
Thanks
Brent
Thanks
Brent
Hello
strange, can you post an example ? I use a lot this method and I don’t remember to have problems.
double t;
curve.ClosestPoint(point, out t);
A = curve.PointAt(t);
No problem here
test cuve cloest point.gh (12.0 KB)
Hi again - please see code below and I have attached GH and 3DM file
Perp Frames.gh (10.3 KB)
string points.3dm (31.0 KB)
public class PerpFramesTwoCurves : GH_Component
/// <summary>
/// Initializes a new instance of the PerpFramesTwoCurves class.
/// </summary>
public PerpFramesTwoCurves()
: base("PerpFramesTwoCurves", "PF2C", "Description", "WSP", "Curves")
/// <summary>
/// Registers all the input parameters for this component.
/// </summary>
protected override void RegisterInputParams(GH_Component.GH_InputParamManager pManager)
pManager.AddCurveParameter("Control String", "C", "Control String", GH_ParamAccess.item);
pManager.AddCurveParameter("Edge String", "E", "Edge String", GH_ParamAccess.item);
pManager.AddIntegerParameter("Spacing", "S", "Spacing", GH_ParamAccess.item);
pManager.AddBooleanParameter("Is Spacing", "I", "Is Spacing", GH_ParamAccess.item);
/// <summary>
/// Registers all the output parameters for this component.
/// </summary>
protected override void RegisterOutputParams(GH_Component.GH_OutputParamManager pManager)
pManager.AddPointParameter("Control String Points", "CSP", "Control String Points", GH_ParamAccess.list);
pManager.AddPointParameter("Edge String Points", "ESP", "Edge String Points", GH_ParamAccess.list);
pManager.AddPlaneParameter("Control String Planes", "CSPL", "Control String Planes", GH_ParamAccess.list);
pManager.AddPlaneParameter("Edge String Planes", "ESPL", "Edge String Planes", GH_ParamAccess.list);
/// <summary>
/// This is the method that actually does the work.
/// </summary>
/// <param name="DA">The DA object is used to retrieve from inputs and store in outputs.</param>
protected override void SolveInstance(IGH_DataAccess DA)
Curve cs = null;
Curve es = null;
int val = 1;
bool isSpacing = false;
if (!DA.GetData(0, ref cs)) { return; }
if (!DA.GetData(1, ref es)) { return; }
if (!DA.GetData(2, ref val)) { return; }
if (!DA.GetData(3, ref isSpacing)) { return; }
//Get points on control string
List<Point3d> controlStringPoints = new List<Point3d>();
if (isSpacing)
double inc = 0;
do
controlStringPoints.Add(cs.PointAt(inc));
inc += val;
while (inc < cs.GetLength());
controlStringPoints.Add(cs.PointAtEnd);
else
double[] d = cs.DivideByCount(val, true);
foreach (double dd in d)
controlStringPoints.Add(cs.PointAt(dd));
List<Point3d> edgeStringPoints = new List<Point3d>();
foreach (Point3d p in controlStringPoints)
bool test = es.ClosestPoint(p, out double d);
if (test)
edgeStringPoints.Add(es.PointAtLength(d));
List<Line> lines = new List<Line>();
List<Plane> csPlanes = new List<Plane>();
List<Plane> esPlanes = new List<Plane>();
if (controlStringPoints.Count == edgeStringPoints.Count)
for (int i = 0; i < controlStringPoints.Count; i++)
Line l = new Line(controlStringPoints[i], edgeStringPoints[i]);
lines.Add(l);
Plane pl = new Plane(controlStringPoints[i], l.Direction, Vector3d.ZAxis);
csPlanes.Add(pl);
Plane esp = new Plane(edgeStringPoints[i], pl.XAxis, pl.YAxis);
esPlanes.Add(esp);
DA.SetDataList(0, controlStringPoints);
DA.SetDataList(1, edgeStringPoints);
DA.SetDataList(2, csPlanes);
DA.SetDataList(3, esPlanes);
/// <summary>
/// Provides an Icon for the component.
/// </summary>
protected override System.Drawing.Bitmap Icon
get
//You can add image files to your project resources and access them like this:
// return Resources.IconForThisComponent;
return null;
/// <summary>
/// Gets the unique ID for this component. Do not change this ID after release.
/// </summary>
public override Guid ComponentGuid
get { return new Guid("6e4b1bf4-ec99-44df-9ce5-bab5a884c982"); }
Any info/tips is greatly appreciated.
Thanks
It is not pointatlenght but pointat!!
The first need a length and the second a parameter. Both double but not the same
Thanks so much for that!!!
