Problem of horizontal/vertical movement
somehow when i dragging objects or drawing curves, it all moves horizontal/vertical without using shift button, how can i fix this? i have restore setting to default and reopen Rhino, it doesn/t help.
Hello - if the ‘Ortho’ in the status bar at the bottom of the screen is bold, click on that to ‘un-bold’ it and Ortho will be off. Or run the Ortho command…
thank you sir!
