i’m stuck with moving objects in an orthogonal way although i have unticked all parameters at the bottom left of the workspace. is this a bug? or this there a function that is activated that i’m unaware of? thanks in advance for your response.
try hitting F8 that usually toggles ortho on and off.
and as Rodi said, that is not to be found in the snaps.
yes it was the ortho function that was activated. haev no idea how i activated it. thank you Rodri!
actually it was the ortho function that was activated. the F8 function is for autocad.
F8 toggles Ortho in Rhino too (unless you’ve remapped it).
