Problem installing on new pc
Hello, we bought a new pc in the company and I need to install Rhino6 (which was installed on the old pc).
I uninstalled the program from the old pc to avoid problems with the license, but I’m not allowed to log in because I always get the error: "Can’t reach Rhino Account server (Request cancelled: couldn’t create SSL/TLS secure channel… .)
Hi Federico -
Just to make sure, which version of Rhino 6 are you installing? Can you post the file name of the installer?
Can you reach https://api.mcneel.com/ ?
If the license wasn’t released and the computer isn’t available anymore you can have the owner of the license contact sales and get it released.
Hi Wim
Here is the file name
rhino_it-it_6.8.18240.20051
-Federico
Please install the latest. 6.35
https://www.rhino3d.com/download/archive/rhino-for-windows/6/latest/
Hi Japhy, after the download can I try to log in again?
Certainly, let us know if there are any issues. If you can reach https://api.mcneel.com/ and have 6.35 with a valid license you should be good to go.
You might end up in a loop where you login, your account tells you there is a license, you go back to V6 and it says you don’t have a license.
If that happens report back.
It’s easy to sort as well.
Grazie mille a tutti, problema risolto.
Ho notato che mi ha salvato 2 programmi: “Rhino6” (il classico) e “Rhino6 in modalità sicura”.
In ogni caso aprono entrambi il programma correttamente.
Grazie ancora e buon anno!!
Rhino 6 in Safe Mode is a troubleshootong tool.
It is not a working mode.
Safe Mode is used when Rhino crashes on startup so you can disable buggy plug-ins or display drivers.
ok John
