Could not create SSL/TLS secure channel
Any help with this? It came all of a sudden and doesn’t allow me to login. Everything else is in order including seeing the license when I login to my rhino account.
Hi @a_hotari,
It looks like you are using a version of Rhino older than 6.13. Please download the latest version of Rhino 6 and this problem should go away.
https://www.rhino3d.com/download/archive/rhino-for-windows/6/latest
Hi @aj1 ,
I have the same problem, however I have the latest version of Rhino 6.8.18 on my computer.
Would you be able to help on that subject ?
Thank you,
Screenshot 2021-04-27 095736 image
Hi Juliette -
As you say, you are running Rhino 6.8 - released in 2018.
The current version of Rhino 6 is 6.34, which was release earlier this year.
Yes, when I did the latest update (6.34 I think) problem was solved.
hi Wim, sorry I had a different number logic… Indeed. will give it an update then. Thanks
