Problem in Rhino 6 scripting
testing Rhino 6 automation i have found a new problem in this simple script:
Option Explicit
 ' Run the subroutine defined above
Call TestRhinoAutomation
Sub TestRhinoAutomation
  Dim objRhino, objShell
  Set objShell = WScript.CreateObject("WScript.Shell")
  On Error Resume Next
  Set objRhino = CreateObject("Rhino.Application.6")
  objRhino.Visible = 1
  If objRhino.IsInitialized Then
    objRhino.RunScript "_Line",1
  End If
 End Sub
somebody can help me to understand where is the problem?
I’m looking into this.
https://mcneel.myjetbrains.com/youtrack/issue/RH-43783
— Dale
Hello Dale , the problem will be fixed in the future? thanks in advance
Hi @achelon,
Looking at the issue, it appears it has been fixed in SR2.
– Dale
Thanks a lot
