Dim objRhino
On Error Resume Next
Set objRhino = CreateObject("Rhino5.Interface")
If Err.Number=0 then
nRetries = 0
Do While (nRetries < 10)
If objRhino.IsInitialized = 0 Then
Call WScript.Sleep(500)
End If
nRetries = nRetries + 1
Loop
Call objRhino.RunScript("_Open",0)
Else
Call WScript.Echo("Rhino initialization failed")
End If
works well (it shows the open dialog file).
But with Rhino 6, the same .vbs script:
Dim objRhino
Set objRhino = CreateObject("Rhino.Interface.6")
nRetries = 0
End If
Loop
Else
End If
does not works (not shows the open dialog file).
Is there a problem of my installation or is a bug?
Hi Dale,
it seems to be happened again.
In Rhino 7.1.20343.09491,
if I run this .vbs script:
Dim objRhino, objRhinoScript, nRetries
Set objRhino = CreateObject("Rhino.Interface.7")
If Err.Number <> 0 Then
Call WScript.Echo("Failed to create Rhino object.")
Else
nRetries = 0
Else
nRetries = 10
End If
Loop
If objRhino.IsInitialized = 1 Then
Set objRhinoScript = objRhino.GetScriptObject
objRhinoScript.Command "_Line 0,0,0 5,5,5"
End If
End If
Rhino does not execute the command
and shows me only a Message Dialog (not in front) asking:
Save changes to Untitled?
With Rhino 7 (7.0) first release, this script works fine.
I’ve tested your code and Rhino 7 is adding your line. If you want to verify this just run this slightly modified version:
Else
nRetries = 0
Else
nRetries = 10
End If
Loop
objRhino.Visible = 1 ' Add this...
End If
End If
Hi Dale,
thank you for your answer.
I tried adding this line:
and a “second instance” of rhino is showed with the drwan line.
The Message Dialog asking
is always showed.
But, how I can draw the line in the “current draw” of the running Rhino without
opening this second instance of Rhino?
Thanks in advance
Hi Dale,
I tested the script with
Rhino 7.2.21012.11001,
and it continue to open a second instance.
But is dropped the possibility to draw in the “current draw” ?
If not, how can I do ?
Thanks in advance
