CreateObject("Rhino3.Application") hangs on Windows 10
On Windows 10, I can’t connect to Rhino3 for External Access.
Task manager shows a process for Rhino3.exe -Embedding
Do I have to regsvr32 some dll?
This results in the error “ActiveX component can’t create object”.
' Try creating a Rhino Application object
Dim objRhino
' On Error Resume Next
Set objRhino = CreateObject("Rhino3.Application")
If Err.Number <> 0 Then
  Call WScript.Echo("Failed to create Rhino object.")
  ' Exit Sub
else
Call WScript.Echo("Rhino object created.")
End If
I have a VB6 application that runs scripts on Rhino3. It works on Windows 7. It’s not working on Windows 10. Is it because Windows 10 is 64-bit?
Hi @user2971,
This seems to work here. This is what I did:
1.) Installed Rhino 3 SR5b on Windows 10 Pro.
2.) Ran Rhino 3 once “as administrator”
3.) Saved the following code to test.vbs:
Else
End If
4.) From a command prompt, ran cscript test.vbs
– Dale
Thank you! It worked after I installed SR5b. I was trying this with SR5.
