This is probably obvious… Used the same sortof beginning lines as usual but first time I’ve had a problem:
Option Explicit
’Script written by Ryan Wynott
’Script version November 25, 2016 9:55:46 AM
Rhino.AddStartupScript Rhino.LastLoadedScriptFile()
Rhino.AddAlias “RenameToMaterials”, “_NoEcho _-Runscript (RenameToMaterials)”
Call RenameToMaterials()
Sub RenameToMaterials()
Dim arrObjects, strObject
arrObjects = Rhino.ObjectsByType(8 + 16 + 32)
For Each strObject In arrObjects
Dim strObjectLayer: strObjectLayer = Rhino.ObjectLayer(strObject)
Dim materialIndex: materialIndex = Rhino.LayerMaterialIndex(strObjectLayer)
If materialIndex = -1 Then
Rhino.Print "The object layer does not have a material assigned."
Else
Dim objectMaterial: objectMaterial = Rhino.MaterialName(materialIndex)
Rhino.ObjectName strObject, objectMaterial
Rhino.Print objectMaterial
Rhino.Print "renamed object"
End If
Next
End Sub
