VBScript Error while running the script using a command in Rhino 5 software
Continuing the discussion from VBScript Error while running the script using a command in Rhino 5:
Hi Paras,
i´m not using VS but just out of curiosity, do you get the same error if you call the sub like this ?
Main
Sub Main()
	MsgBox "Hello World!"
End Sub
i´m unshure but if i remember correctly a call statement tries to create a return value even if there are no arguments. @dale can you answer this ?
And do you get an error at all if you completely leave out the call to Main above but call your routine by using this from a toolbar button once the plugin is loaded in Rhino:
! -_RunScript (
Main
c.
