Problem Exporting OBJ from Rhino 8 to 3dsmax 2023
I recently was working between rhino and max like I usually do. When I export an OBJ from Rhino 8 to open in the 3dsmax (2023) it just makes garbage. I have to resave to rhino V7 to re-export a successful OBJ. Wondering if this is a bug, and if anyone else has had this issue?
check your obj export settings between 7 and 8, are they identical?
That might be it. I see one difference between the default ticks. I’ll test and post results. thx
solved.
Default is set to “do not export object names”
