Hey,
unfortunately it seams that the OBJ. - export is broken in the current version of rhino.
or is it just me?
B
Hey,
or is it just me?
B
Hi Benjamin,
It looks good over here, what problems do you have?
What version of Rhino are you exactly running?
-Willem
Hi Willem,
please find attached a screenshot of the obj-export options I used, one of the import options in max and one of the result.
There were never issues before (rhino 4).
B
Hi Benjamin,
I have seen that type or error (extra faces at seemingly random places) however I thought that was
’fixed’ by using the As OBJ groups settings like you use it.
I do not have 3dSmax here so I cannot test it.
Benjamin, what version of Rhino are you running?
@Pascal is there a known alteration of the OBJ exporter recently?
-Willem
Version 5 SR3 (5.3.30426.17065, 26.04.2013)
Commercial
Hi Benjamin,
Can you try updating Rhino? I’m running Version 5 SR6 64-bit (5.6.30918.7015, 9/18/2013)
Go To Help -> Check For Updates and see if you are up to date.
-Willem
obj-export is still broken in the current version (SR8).
Hi Benjamin,
Can you provide a 3dm file please? Also, what does the obj look like when opened in Rhino?
hey,
obj-export is still broken in rhino 6 SR18.
Cheers B
Hi - please provide a 3dm file that does not export correctly.
