Problem after instalation nvidia experience drivers
Hi. I have problem with rhino.
I update drivers of my graphic card Geforce 1050Ti Notebook.
I instaled experience from nvidia which make the best setings for games.
After that when i was runing rhino i have only black view. I didn’t see anything.
After that i set in computer graphic from procesor and all was fine.
I uninstal and instal drivers few times, unistal and install rhino and now Rhino don’t show anything even on procesor.
I don’t know what to do.!
Hello - please run the SystemInfo command in Rhino and post the results.
I found that I had to uninstall Nvidia Experience the one time I installed it on my Rhino machine.
Rhino 6 SR30 2020-10-14 (Rhino 6, 6.30.20288.16411, Git hash:master @ aa50c15036dbe0dbd38214d6ca94d76dbecda24d)
License type: Edukacyjna, build 2020-10-14
License details: Cloud Zoo. In use by: Michał Krawiecki ()
Windows 10.0 SR0.0 or greater (Physical RAM: 7.9Gb)
Machine name: DESKTOP-8JT5FD6
Hybrid graphics system.
Primary display: Intel(R) HD Graphics 630 (Intel) Memory: 1GB, Driver date: 6-2-2017 (M-D-Y).
Primary OpenGL: NVIDIA GeForce GTX 1050 Ti (NVidia) Memory: 4GB, Driver date: 9-30-2020 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 456.71
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 9-30-2020
Driver Version: 27.21.14.5671
Z-Buffer depth: 24 bits
Total Video Memory: 4 GB
Rhino plugins
C:\Program Files\Rhino 6\Plug-ins\Commands.rhp “Commands” 6.30.20288.16411
C:\Program Files\Rhino 6\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 6.30.20288.16411
C:\Users\Krawiec\AppData\Roaming\McNeel\Rhinoceros\6.0\Plug-ins\Lumion LiveSync for Rhino (839d6175-32d1-4ffe-a0a4-b7fb43cf0ff5)\2018.10.30.683\Lumion\Rhino 6.0\LumionPlugin.rhp “Lumion LiveSync for Rhino”
C:\Program Files\Rhino 6\Plug-ins\RhinoCycles.rhp “RhinoCycles” 6.30.20288.16411
C:\Program Files\Rhino 6\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 6.30.20288.16411
Hi - can you describe your hardware configuration? Do you have external monitors attached? How many, to which ports?
Hi
laptop acer vx15
intel core i5 7300hq
nvidia geforce 1050 ti
8gb ram
ssd 500gb nvme
i was using extra monitor by hdmi i have also usb c socket, but don’t use it
at this moment i am using only laptop display
Hello - just to eliminate the possibility, please disable the above plug-in in Options > Plug-ins page , then close and restart Rhino and see if that makes any difference.
Tthanks for your idea, but its not working.
I also try to disable different plugins, but still the same.
I try to double click on name of view and after that i have normal view, but rhino is working very very slow. I dont seen what i am doing, after that I again clicking on view name and at this moment it showes me what i draw.
It isn’t conected with plugins. I wroting about this becouse i discovered it.
Hello - I just noticed this - please update the Intel drivers to the latest available from the website. If that does not help, can you please set the NVidia control panel to use ‘High performance’
