Printing rhino 8 normal printer not usable
when printing with R8 normal printer , seting portret window scaled to fit does not print portret but landscape , view is the same when setting landscape
printing landscape does not print the setting window but half of the window approx
result this
check the scaling settings.
that is exact as i need , scaled to fit the A4 sheet , it does not print as it should see the pictures
Which build number you are running?
last one updated today
Hm - I do not have A4 paper, so I can’t test directly, here. 8.5x11 in. does do the right thing on my printer.
@robo does pdf spit out the correct aspect ratio?
good luck getting the print to look the same as the preview
rhino pdf seems to work here , but normal hp laserprinter does not print portret , it prints landscape when printng portret , in R7 it works good this printer , i do not think it is the A4 or 8,5x11 it is just not printing what it should , it looks ok see the pictures, but the result is no good(last picture) , here on my laptop i do not have a normal printer only pdf print and that seems ok landscape or portret.
grts
saved a rhino pdf of the parts i wanted to print ,and printed that on the normal printer , this seems ok.
Did a scale 1:1 print pdf, printed that and that printed out ok
I wish I had a similar printer so I could reproduce the issue.
just to make sure, are you running release Candidate or Release? Is it 8.2? or 8.3?
sr3 and it is just a standard windows printer HP laserjet pro 200 color , it works in al previous rhino versions really ok
I have the same problem as you. Developers don’t even do the most basic tests, they are really a group of geniuses.
I don’t have a laser printer just an old HP inkjet. This is what I see:
Portrait:
Landscape:
The actual paper prints look just like the preview. What am I doing differently?
well my print is portret and the outcome is landscape , when printing landscape the outcome is just a part of the window you set over the parts to print , the preview is ok the outcome partly and not in the scale you want
it works in R7 excellent
grts
OK, that’s not happening to me here, but I don’t have your printer. Do you have another printer to test if the same thing happens? What happens if you print to PDF?
look above allready tested
So it seems printer-specific… (driver?)
Nothing specail on this printer works in all progs also Rhino 7, 6 and 5
Thanks for all these details. I think we’ll need to set up a remote debugging session with you to see if we can figure out what is different about your printer compared to all the ones we’ve tried. I’ll send you a DM with more details.
Hi Rob / Brian,
I was able to reproduce this on my old Lexmark E232 and wrote this up as RH-79378 Print: Printing to physical printer prints layout instead of portrait
