I was working on a project in Rhino 7 when I downloaded the Rhino 8 demo . The pen display in layouts worked much better in R8 so I continued in R 8 with no problems until I tried to print a couple of layouts . Sometimes the line types were excessivly fat and other times details would be missing . I tried several pdf creators as well as my two printers and no luck . This was a breeze in R7 so I tried saving my project in R7 format and it just crashed R7 . I’m planning to buy the R8 upgrade , but am wondering if all of my printing issues are because I’m using a trial version ?
There have been changes and ongoing improvements in this department so please keep up to date. If you can post a small file of what you are seeing and your systemInfo we can take a look. Thanks
The trial version is an expiring license on a fully functional Rhino instance.
part I.D pdf light.pdf (555.4 KB)
This is the type of output I’m getting with the details in layout set to pen
I believe the bug you are seeing is something I just fixed yesterday. Here is a build of Rhino that should fix the printed pen display output
https://files.mcneel.com/dujour/exe/20240111/rhino_en-us_8.4.24011.01001.exe
Thankyou for the update !! It’s working the way that I expected it to now
HI Mike -
But what does the PDF look like? We’ll need a 3dm file if more work is required here…
the pdf looks fine on a screen resolution , but I email PDF files to be printed by clients . I’d be happy to send the 3dm file , —Do I drag it to the window here ? or email it ?
Hi Mike -
If you don’t mind the 3dm file being public, yes, please just drag it into the window here. Else, there’s https://www.rhino3d.com/upload
The file is to big to drag here , I’ll upload it . the file is called deck plans with sections
sorry I didn’t have an email to send it to , I uploaded it without an email
Hi Craig -
I can’t reproduce this in a quick test here. Could you provide both the output of the Rhino SystemInfo command and a simple 3dm file that shows the behavior?
Here you go.
TEST.3dm (11.2 MB)
In the Rhino file, you’ll see the cover page viewport using the Pen display mode shows up correctly before printing, but in the print preview the edge lines change to using the color associated with each object’s layer.
