Printer settings ignored in Rhino 8?
The paper size setting and orientation are being igored.
Whatever setting I choose, it will always print A4 - landscape.
Any ideas whats causing this? Other apps on my PC don’t have this issue
Edit: I can’t test on a second physical printer, but the Rhino PDF creator does seem to create the correct size and orientation.
Hi Simon,
What service release are you running? Anyone with printing issues should be on 8.5 and above.
Go to File>Properties>Updates and change to service release candidate for the latest. Thanks
thanks that might have fixed it.
(not wanting to waste too much paper, I only did one test print, which seemed to work)
Personally I have always printed to PDF first (regardless of application), too many trees felled for my mistakes already.
