I went to staples to have some drawings printed full size. They tell me that I need to save the file as a PDF with a paper size of ARCH-E this option is not available in the Rhino save as comand save as PDF. This comand doesn’t have the ARCH paper sizes.
I’d recommend a different PDF authoring tool like www.pdf995.com or www.bullzip.com.
They both have free versions and install into Windows as “printers”. Then they will work with any Windows application including Rhino.
You would use the Print command in Rhino, choose the PDF995 or BullZIP printer, and desired sheet size.
Thanks I’ll give that a try.
Thanks I will try that.
