PrintDisplay Command not updating line weights live on Rhino 8 Mac
Hi! Does anyone know how to fix the issue with the “PrintDisplay” toggled on, but line weights aren’t showing??? I did assign the layers with the changed “Print Width”.
hello @Gabriel_Nguyen pls run _SystemInfo in Rhino and post back the results. A sample file would be helpful too. is this in model space, or layout space?
HI! I did it in Model Space. I was making drawings with lines and having print display “ON” as I was producing a drawing. I ran the _SystemInfo and attached the file below that I used.
System Info.txt (4.8 KB)
Sample File M04 Rhino 8.3dm (7.8 MB)
hi @Gabriel_Nguyen You will need to set the display scale quite high to see a difference in line width. Your model is in feet, while the line is set to 0.35mm. Turning on PrintDisplay and setting the scale to 60 gives me this:
is that what you are after?
Thank you so much! It finally worked!
