Layout Linetype Display
Is there a way to have the linetypes display at the correct scale in Layout mode?
I know I can change the print settings to “Match Pattern Definition” which prints the lineweights correctly, but does not display them correctly while in Layout.
I think what you’re looking for is the PrintDisplay command.
Thank you Vanessa. Here is another way to explain what I would like to do:
I want to be able to set a linetype scale in model space (e.g. 48) which affects the lines drawn in model space.
And then set a linetype scale in layout for lines drawn in layout (e.g. 1).
Is this already a command somewhere?
