I wonder if anyone else has noticed this, but when you set the Print Setup for Rhino PDF, the Resolution keeps coming up to 600 dpi. If you manually go in and change it to 300 dpi it will Print that way but when you close the file and open it again it will be back at 600 dpi.
It’s not a huge problem but if you are doing a lot of printing (which I do) it gets annoying…
I’m using Rhino 7 SR26 with Windows 10.
Thank you.
