Print PDF Issue - Vector Output
Hi guys, a week ago when I print PDF in Rhino 8, it was all fine.
As shown below, it was the vector output with correct text spacing.
I remember there was an update during this week. Today when I exported the same file to PDF, it became like this:
The spacing between texts were different. And the size of the texts were also a bit different. I tried many ways to slove this problem but none of them worked. The closest approach to the solution was using “Raster Output” instead of Vector Output”. Thought it has the same text spacing with the version a week ago, it’s a raster (image) file…
I used AutoCAD to print PDF to check if it was the printer’s issue, but it was all fine. Hope someone know what’s going on. Thanks!
Hi -
Do you remember which version of Rhino you were running before this update?
Could you post a 3dm file so that we can take a closer look?
Hi Wim, thanks for the reply. The problem is solved when I use Chinese font. In the above images the font were arial. Not sure if it’s still an issue but it works for me now.
