I’m sure this is a bug that needs fixing.
I’m trying to PRINT MULTIPLE LAYOUTS @ 1:2 SCALE. The layout is A1 at 1:1 scale, I want to print A3 (1:2scale) to proof before printing full size.
There’s a centering error when doing this. Because the center position is locked for the layout setting in [margins and position] theres no way to change the location in print multiple layouts. The centerpoint should stay set at the layouts center.
this is an example file Print Scale Error example.3dm (131.4 KB)
screen grabs from printing that file.
here if the print size is 1:1 as in the layout its correct (obviously)
but when scaling the layout it scales the centerpoint as well as the dimension of the layout.
I know that I can print 1:1 to PDF and then scale the PDF in a the PDF print dialogue. But that is not fixing the problem with rhino’s print dialogue.
I hope that’s clear enough
