Print Layout to RhinoPDF crashes Rhino
Running Windows 10 on an iMac via MacOS 11 and Bootcamp. Whenever I try to print a Layout to RhinoPDF, I get the output sought but Rhino crashes. This seems to be a problem with a single Rhino model, which I’ve attached for your viewing pleasure and crack analysis!
Sxx_GirderReinforcementPlans_r1.3dm (2.5 MB)
Any explanation for the weird behavior?
I can’t find anything wrong with the file and I can not duplicate the crash.
I printed Vector and Raster using RhinoPDF from both Layouts in Rhino V7
Maybe run SystemInfo in Rhino and post the results.
Hopefully something will show up.
Thanks for looking into this, John. I checked every object in the model and all came up valid. But the problem still happens with the model I uploaded for both its layouts, but not with layouts in other Rhino files. When I print to RhinoPDF, Rhino slams shut without a crash dump.
The day before I noticed the print to RhinoPDF problem, the file would crash and I’d see the sad Rhino with the deflated beach ball. I believe I sent a few of those reports. In most cases, it crashed while I was trying to select a line or a line control point.
I still have two of the crash dumps, but they appear to be copies of the model file that crashed. I’ll upload them if you want to see them.
From SystemInfo:
Rhino 7 SR5 2021-4-10 (Rhino 7, 7.5.21100.03001, Git hash:master @ 2cd158094b595f6400479d7cbe511454b6149527)
License type: Commercial, build 2021-04-10
License details: Cloud Zoo
Windows 10.0.19042 SR0.0 or greater (Physical RAM: 64Gb)
Computer platform: DESKTOP
Primary display and OpenGL: AMD RADEON R9 M395X (AMD) Memory: 4GB, Driver date: 10-5-2015 (M-D-Y). OpenGL Ver: 4.5.13407 Compatibility Profile Context 15.201.2001.0
> Accelerated graphics device with 6 adapter port(s)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.5
Shading Language: 4.40
Driver Date: 10-5-2015
Driver Version: 15.201.2001.0
Z-Buffer depth: 24 bits
Total Video Memory: 4 GB
C:\Users\fdrou\AppData\Roaming\McNeel\Rhinoceros\7.0\Plug-ins\Flamingo nXt 5.0 (fd53f8c4-546d-47d1-8820-e66c97645a97)\5.5.18347.11581\5.5\Legacy\Flamingo.Legacy.dll "Flamingo nXt Legacy File Reader " 5.5.18347.11581
C:\Program Files\Rhino 7\Plug-ins\Penguin 2.0\Penguin.rhp “Penguin 2.0”
C:\Users\fdrou\AppData\Roaming\McNeel\Rhinoceros\7.0\Plug-ins\Flamingo nXt 5.0 (fd53f8c4-546d-47d1-8820-e66c97645a97)\5.5.18353.6521\5.5\Flamingo.nXt.rhp “Flamingo nXt 5.5” 5.5.18353.6521
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.5.21100.3001
C:\Program Files\Rhino 7\Plug-ins\AnimationTools.rhp “AnimationTools”
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.5.21100.3001
C:\Program Files\Rhino 7\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.5.21100.3001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.5.21100.3001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.5.21100.3001
Hi -
Please update the drivers for your GPU.
Thanks for pointing that out. I now have updated AMD drivers for Windows on Bootcamp per Apple’s website:
SystemInfo now shows:
Primary display and OpenGL: AMD RADEON R9 M395X (AMD) Memory: 4GB, Driver date: 9-10-2020 (M-D-Y). OpenGL Ver: 4.6.13596 Compatibility Profile Context 20.10.36.01 27.20.11036.1002
> Accelerated graphics device with 8 adapter port(s)
Unfortunately, the problem persists. When I try to print a layout to RhinoPDF, Rhino crashes but I get the desired print. It only happens with this particular model file.
iMac 27-inch 5K (Late 2015) running Windows 10 via Bootcamp. Another file now crashes every time that I try to print a layout to PDF. Yes, I’ve updated my video drivers, and no, it didn’t make a difference. This is the file:
S04_FoundationPlan-1.3dm (1.1 MB)
There’s also a associated “S04_FoundationPlan-1.3dm.rhl file,” but I don’t know what it is and I can’t upload it here.
Any idea what it going wrong?
I get the same problem unfortunately :frowning:
