Prevent selecting/picking surfaces (while cross selecting)?
Hi to all,
I’m wondering how to prevent selecting surfaces in Shaded mode? I like to cross select control point of particular surface but when I start with window selection and pick first point of window I pick the unwanted surface (if picked point lie on area of the surface).
I know that I can switch to Wireframe mode and do the selection but the procedure is to long and also tricky.
Surface pick
Hi
You can use selection filter by click (f5) or another way, hold ctrl+shift and select any vertex or edge you want.
Hold down the Alt key when window selecting, it will prevent the mouse click placing the first corner of the the window from picking objects.
Yes, ALT key when window selecting! That’s what I wanted:).
Thank you Halvetosaur
This also has the potential to help, if it ever gets implemented in Rhino:
