Tom_P
May 30, 2023, 9:08pm
1
I need a RhinoGet , Input.Custom.GetObject to get a Surface / Face Selection only with a valid Pick-Position / u-v Parameters.
Can I somehow force the user to only select by clicking on the surface / Face ?
no window / cross selection, no _selID, _selName etc… ?
the _filletSrf Command has the behaviour I need.
thanks / kind regards -tom
Hi @Tom_P , this is the closest i could get, extracted from another script which allows single surfaces and sub-surfaces to be picked:
GetSurfaceByPicking.py (2.4 KB)
Note that it does not prevent the user from performing a window or crossing selection but keeps prompting if the selection is not from a mouse pick.
I could imagine a different method (using GetPoint) which shoots a ray from the camera location on all breps and then finds the surface and parameter. During GetPoint you cannot perform a window or crossing selection…
_
c.
jim
May 31, 2023, 12:46am
3
This is what I used to mimic FilletSrf behavior:
gs = Rhino.Input.Custom.GetObject(); gs.SubObjectSelect = True;
gs.GeometryFilter = Rhino.DocObjects.ObjectType.Surface
gs.DeselectAllBeforePostSelect = True; gs.AcceptNumber(True,False);
gs.OneByOnePostSelect = True; gs.DisablePreSelect();
I might add that the documentation for Rhino Common is atrocious. Documentation is mostly either missing or wrong.
I spent many hours experimenting to find what works.
And when Help is requested, from what I have observed, that is worst than useless. Time and again I have observed those who make such requests will just be led off into the weeds on a wild goose chase. The only helpful responses are from other users.
dale
(Dale Fugier)
May 31, 2023, 12:50am
4
Hi @jim ,
When you find this, please let us know.
Thanks,
– Dale
dale
(Dale Fugier)
May 31, 2023, 1:06am
5
Hi @Tom_P ,
You might check ObjRef.SelectionPoint , which returns the point where the selection occurred. Otherwise, Point3d.Unset is returned.
ObjRef.SurfaceParameter is also a good method to use for checking.
But, GetObject.OneByOnePostSelect is probably what you’re looking for.
import Rhino
def test_pick_surface():
go = Rhino.Input.Custom.GetObject()
go.SetCommandPrompt("Select surface")
go.GeometryFilter = Rhino.DocObjects.ObjectType.Surface
go.DisablePreSelect()
go.OneByOnePostSelect = True
go.Get()
if go.CommandResult() == Rhino.Commands.Result.Success:
objref = go.Object(0)
srf, u, v = objref.SurfaceParameter()
if srf:
print u, v
pt = objref.SelectionPoint()
print pt
if __name__ == "__main__":
test_pick_surface()
– Dale
Tom_P
May 31, 2023, 8:17pm
6
thanks @dale
OneByOnePostSelect was the missing line / property, what I was after.
I think the RhinoCommon API is great and very powerful.
regarding the documentation for this specific case:
https://developer.rhino3d.com/api/rhinocommon/rhino.input.custom.getobject/onebyonepostselect
should have some hint to other similar keywords :
(selection, window, crossing, mouse…)
I was totally miss-led by the stuff i found…
then searched for similar keywords without success…
https://developer.rhino3d.com/api/rhinocommon/rhino.input.custom.pickstyle
https://developer.rhino3d.com/api/rhinocommon/rhino.docobjects.selectionmethod
kind regards -tom
