having an issue where if my linked block has a point in it, it will only show as wireframe. If I go into the block and delete the point, it will show as shaded. If I go back in and add point… Wireframe.
I want to use points to register different parts together. In this case so that I can snap the brake to the windlass in the correct position and rotate it.
Yeah it works fine if I make a test model with just a box and a point. IDK … And just inserted another instance of the problem block and that one’s fine… So must be something flukey. Attached block anyway if you want to look.
