Hello, is there any way to match a subd edge to a curve? Thank you
There’s a command for this in Rhino 9 WIP…
Thank you. I tried moving points to curve with near snap on but its complicated.
Use Align > ToCurve with the edgeloop selected. Technically this aligns the control points of the SubD edge to the curve but with that many faces it should be close.
Thank you this works perfectly.
I am late to the party, but like Martin said, SubDMatch
is a command in Rhino 9 WIP that could help you match boundary edges of a SubD to a curve.
