is there a way to constrain a Sub D form to a curve?
Or can I match a sub D loop to a Sub D friendly curve?
thanks
Perhaps try aligning the sub D vertices to the curve.
Select vertices β Align β To Curve β Select target curve
The curve needs to be placed close to the desired area of the sub D you wish to constrain.
I hope this helps.
Hello @marc3! We have just added a new test command that will help you to match the boundary of a SubD to a SubD friendly curve. The command is called TestSubDEdgeMatch and is available in the latest release Rhino 8 WIP. Check out this thread for more details: TestSubDEdgeMatch: A new command to match SubDs to other Rhino objects
Very good news. Thank you!
Ye ol Tsplines had it.
Regards
marc
<img width=β151β height=β201β style=βwidth:1.5729in;height:2.0937inβ id=βPicture_x0020_2β src=β//cdck-file-uploads-global.s3.dualstack.us-west-2.amazonaws.com/mcneel/uploads/default/original/4X/c/6/1/c6194cbbc030b6d7f95400ebaaf8f8122451437f.jpegβ alt="A screenshot of a cell phone
Description automatically generated">
