Pull SubD Vertices to Curve?
Is there a way to do this? T-Splines (please forgive me!), if I recall, had this functionality. I mean any curve, not just something for which you could use `Set XYZ Coordinates. Thanks.
there are similar topics:
Alias’ “edit by curve”…
you should be able to
_align … to Curve
_pull … to a Surface
maybe give an example of what you re trying to achieve if above does not help.
kind regards -tom
Thanks Tom. Align to curve seems to work alright. The results seem more predictable when aligning curve to curve than with points to a curve. Guess I need practice.
