YOUR PORTFOLIO POST FOR THE McNEEL FORUM (with both portfolios: the one of 21 Oct + your Industrial Design PDF)
Where: discourse.mcneel.com › + New Topic › category Jobs & Portfolios › paste the TITLE into the title field
and everything between the two lines into the text field › Create Topic.
42 pictures: 16 are online already (hivemaster.art, paraflow.art); the 26 from your PDF go online on
paraflow.art/img/portfolio/ with your yes (nothing else on the site changes). Post it after that.
The YouTube link shows as a player. Facts: your portfolio of 21 Oct; the PDF pictures are captioned only with
what they show (tell me which were built and for whom, and I add it).
TITLE:
Portfolio: festival stages, parametric furniture and Grasshopper-to-CNC systems · open for freelance work and 1:1 training (Vienna / remote)
Hi everyone, I’m Björn Jelinek (PARAFLOW · HiveMaster), a computational designer near Vienna. For 20 years I have worked between design and fabrication, more than 15 of them with Rhino and Grasshopper: from a parametric definition to the production files and the build on site.
In numbers: stages built in 3 countries since 2015 · a 30,000-LED stage system · thousands of laser-cut parts drawn by definitions · 14 published Grasshopper definitions · CNC, laser, 3D-print and KUKA robot toolpaths out of the same files.
1 · Stargate series, Hive Stage · MO:DEM Festival, Croatia (2015–2023)
A gate that grew over a decade: the first Stargate in 2015, the full LED array in 2016, Stargate 2018 with the DNA Tower, Stargate V2 in 2021 and 2023. It stood on the Hive stage for about ten years.
- Thousands of laser-cut plywood parts, drawn by a definition, not by hand
- Backed with LED fabric and reflective plastic; a 30,000-LED system of high-refresh fixtures
- V2: the surface cut so it reads as one continuous pattern, projection-mapped through the night
2 · Ocaso Festival · Guanacaste, Costa Rica (2019, 2020)
- 2019: a metal frame stretched with Lycra, carrying 11,000 to 12,000 LEDs
- 2020: the same construction on a bigger scale: over 20 m across, around 15,000 LEDs and a hologram at the centre
- DJ front LED shield: a round plywood panel about a metre across, cut flat, lined by hand in gold and silver
3 · Monegros Desert Festival · Aragón, Spain (2023, 2024)
A stage facade for a 40,000-capacity desert festival: DNA helices, hex fields and circular eyes, carrying the same 30,000-LED system, built on site in the desert. Delivered as Senior Computational Designer & Manager at elrowFamily (2022–2025): Grasshopper systems for modular stage environments, build planning, and on-site installation with the lighting, audio and rigging teams.
4 · The stages before they are built: the Rhino models
Every stage starts as a model that already knows its parts, its supports and its line work for the cutters.
5 · Studio pieces
- DJ booth front for the Extra Delicious crew in Norway: a hexagon field and fanned blades over the LEDs, so the whole front reads as one moving surface
- Neural Program Premium: acrylic mirror inlaid into marine plywood, so the circuitry catches the light
6 · One definition: the piece and its CNC sheets
My own Grasshopper definitions: move a slider, and the form and the cutting files follow.
- Astra Table Stellar: 38 sliders · 44 ribs + 43 spacers · 15 mm plywood · 9 nested CNC sheets with engraved part labels
- Bench: 60 sliders · 113 parts · 19 mm plywood · 36 CNC sheets · 40 threaded rods · the cutting curves baked for RhinoCAM
- Astra Table Warp 2: 31 sliders · 118 ribs · 24 mm plywood
Shelf, 6 × 2 m, 19 mm pine (Vienna 2020): the wave was found with sliders on a freeform surface, then unrolled, nested and slotted to the millimetre.
7 · Interiors, objects and architecture
A timber pavilion with laser-cut ornament panels: one frame, and the panels swap between pattern systems.
8 · The logic behind the form: my own Grasshopper tools
Screens from live files, not course examples.
- Pocket dog bones: dog-bone corners for CNC-cut pockets and slots, so the joints fit
- Drill holes along a line: the holes placed along a line, driven by sliders
- Hyper Skin: Voronoi and hexagon skins inside any outline, scaled down by attractor curves
- Square Grid Sampler: a quad grid inside any closed curve (quad remesh, adaptive size, edge offset, extrusion)
- Tentacle Detail designer and a spine pattern grown from one input curve, ready for the laser
9 · Form studies
10 · Robotics and automation
- Fiber Elements (2025–2026): Grasshopper workflows for robotic fabrication, automated toolpaths with RhinoCAM and KUKA|prc
- A web-based parametric table configurator: 60+ parameters, live 3D preview, the customer’s configuration goes straight into the inquiry
- n8n workflows and AI agents around the design-to-production process
What I take on
- Grasshopper definitions for fabrication: slicing into ribs and waffles, unrolling, nesting, dog bones, labels, DXF and G-code for CNC and laser, STL for print
- Fixing and cleaning up existing definitions: data trees, slow solves, a handover a colleague understands
- Stages, installations, interiors and objects from concept to production data and the build on site
- 1:1 or team training in Rhino 8 and Grasshopper, online or in Vienna, in English or German, always on your own project file
- Automation: n8n workflows and AI agents around the design-to-production process
Contact: send me a message here, or describe your project at Enquiry — Rhino & Grasshopper training | PARAFLOW. I reply with a fixed price before any work starts.
More: stages and sculptures at The Galaxy — Hivemaster · 14 published Grasshopper definitions at HiveMaster — Inspire, share skills and create | Patreon
IF THE FORUM SAYS “new users can only put one image / two links in a post”:
your account is still new there. Then use the short version in “6 McNeel forum - short post (new account).txt”
with the one portfolio picture, and post the full one a few days later (the forum lifts the limit after you have read
a few topics).
