Didn’t find the solution elsewhere. I’m using rhino on windows, but on a mac in bootcamp. Does’nt have problem before, until I reinstall my computer system. I have few friend who have the same problem and they have recent cumputer (mac too in bootcamp if I’m not wrong).
The short cut is well set in the Keyboard (proprieties), and YES, we use the fn keys to acess the F-- function. Actually, all the other F-- shortcup work except F10 and F11, so the Points On and Points Off.
Did someone have ever had this problem? Solutions?
I see this all the time with students on Macs. You should be able to hold the FN key and press F10/F11 to get these shortcuts. I think the reason they don’t work has to do with an OSX assignment to these that the bootcamp drivers can’t get around in some set ups. Does holding FN work? I can’t tell if you are holding FN or if you just changed a setting.
Thanks for your quick answers, but as I said the other F funtion work normally, as the F8 for the ortho mode,there’s no probelm with this one and the others. It’s only the F10 and F11 who’s bugging. Yes yes yes we are holding the FN…
And yeah, mac it’s a bit a lot of troubles, not my first choice unfortunatly… but yeah now we deal with it.
Yeah this is what I do for now, but it’s a bit annoying as a solution… I’m really use to my old shortcut, and I quite find it stupid to learn new shortcut because there’s a bug somewhere… but if I find no solution I’ll probably just do that.
