Overriding FKey defaults in Mac to use Rhino Shortcuts
Anyone know how to override the fkey commands so that when in Rhino you can make use of these keys for Rhino commands.
Example:
f10 (points on) will turn points on
but
f11 (points off) will turn up the volume on my speakers and not run the rhino specific command
In OSX System Preferences>Keyboard you should have the option to use these keys as you want. You can then hold the FN key at the same time if you want the other behavior. f11 is mapped to some OSX feature I don’t use still but esc turns off the points just fine until I figure out what’s controlling f11 now. Hope this helps!
ahhh… Mission Control is hooked up to f11 and f12 so you have to manually change those too.
