Is it just my system? Latest V6 CR —-Mark
Hi Mark,
Works OK here in Version 6 SR30
(6.30.20246.16281, 9/2/2020)
Hello - are these correctly assigned in Options > Keyboard?
Thanks
Yes, I checked that . No big deal for now.
Hm. Have you closed and restarted Rhino? And do other shortcuts work?
I will wait for another service releato forum.txt (2.4 KB) se and see that changes anything. For now just typing PON. thank you. oh, and yes opened and closed since 2 days ago.
Hello - you can also try disabling VRay in Options > Plug-ins and then restarting Rhino - not likely to be it, but you never know.
Also didn’t help when disabling Vray
Hello - do the other shorcuts - F1, F2 etc work?
Can you try, with Rhino closed, renaming this folder temporarily -
%APPDATA%\McNeel\Rhinoceros\6.0\settings
then restart Rhino and see if it all works?
You’ll get a clean default Rhino starting with a new folder generated. (the renamed one will stay put so you can revert)
i think your on to it. No, the other keys don’t work. Still want me to rename that folder?
Hi mark - you can rename that folder or just the file inside it called
settings-Scheme__Default.xml
I do not know that it is the thing, but it may point to the problem if it behaves differently with default settings.
Sorry to be such a dunce, but you may have to tell me where to rename the folder you want renamed.
Would I go to the control panel or apps. I don’t do this everyday ( or ever) . Maybe I will learn something .
Hi Mark - if you open Windows Explorer and in the address bar, paste:
%APPDATA%\McNeel\Rhinoceros\6.0\settings and Enter
that folder should open. The file I mentioned above should be in that folder.
Any luck?
Hi Mark - rename the top one - you can just add “_OLD” to the current name.
“settings-Scheme__Default_OLD.xml”
Anymore ideas? I followed your instructions
With no change.
OK - revert your settings file to the old one (close Rhino, delete the new settings file, rename the old one)
F-keys work in general on your system, correct? Just making sure it is not a busted keyboard or something external to Rhino…
