Points list display
I divided two curves in grasshopper and marked the points using Points List component. The issue I am facing is the numbers are intersecting with the curves. Is there any setting by which I can position the numbers outside the curves so the diagram looks clean.
Thank You.
Best,
Bhavana
You can move (copy) the points to where you prefer the labels, disable preview on the moved points and apply the Point List to the hidden points instead of the visible points.
3. Attach minimal versions of all the relevant files
Maybe offset the curves by the text height in one direction or the other, pull the points on the original curve to the offset curve with closest point, then put the numbers on the offset points?
Thank You.
