Re-ordering list item numbers
Hi everyone,
I’ve been trying for some time to work out a way to create a curve through some points, but in the right order (the points are derived from x3 separate lists). Can anyone advise how to re-label the points, so that the curve I draw weaves through them in an undulation?
Seems like you need weave, but that’s just a guess based on a quick look at your script, and without seeing the actual script
Can you upload your gh definition? It would be way easier to help you that way.
I think a strategy would be to use Curve Closest Point to pull the points to the curve, and then use the curve parameters to sort the points.
Thank you Devin - maybe the attached will help?UNDULATING_CURVE.gh (12.4 KB)
UNDULATING_CURVE_ign.gh (17.5 KB)
Like so?
That is the aim! Yes, thank you - will try this and hopefully will understand what you’ve done… thank you again!
Yep, that’s fantastic, thank you again @lgn24680 - much appreciated and wish I’d posted sooner!
UNDULATING_CURVE_POINT ORIENTED.gh (18.9 KB)
The Point Oriented command in combination with Curve Frames can be really useful to create a more robust definition, regardless of your circle being flat or not.
I wouldn’t offset the curve and dispatch.
Instead dispatch first, move some of the points and then weave everything into one list again.
dispatch_weave.gh (17.6 KB)
Another solution would be a spiral around a curve projected onto the XY plane but it requires a python script:
spiral_around_curve.gh (16.8 KB)
