I am trying to get a useable and visible model of a scan that I imported as a point cloud via E.57 format. The scan is perfect - as I can visualize it in CloudCompare. After the import the rhino file has a certain file size and the import worked in my understanding. But I can only select and zoom to an object that is not visible. I do not see the point cloud itself? Any ideas how to solve this issue?
Hi -
Please run the Rhino SystemInfo command and copy-paste the result here.
Rhino 7 SR16 2022-3-8 (Rhino 7, 7.16.22067.13001, Git hash:master @ aa7902c94c5aa33511e60d30f82b636be43bc85f)
License type: Kommerziell, build 2022-03-08
License details: Cloud Zoo
Windows (Physical RAM: 0.98Gb)
VersionMajorMinorServicePack failed
Computer platform: DESKTOP
Primary display: Parallels Display Adapter (WDDM) (Parallels) Memory: 501MB, Driver date: 5-30-2022 (M-D-Y).
> External USB display device with 7 adapter port(s)
Primary OpenGL: Parallels using AMD Radeon R9 M370X OpenGL Engine (Compat): Parallels and ATI Technologies Inc… OpenGL Ver: 3.3 ATI-2.11.26
> No graphics device is being used for OpenGL
OpenGL Settings
Safe mode: Off
Graphics level being used: OpenGL 3.3 (primary GPU’s maximum)
Anti-alias mode: 4x
Mip Map Filtering: Linear
Vendor Name: Parallels and ATI Technologies Inc.
Render version: 3.3
Shading Language: 3.30
Driver Date: 7-15-2015
Driver Version: 15.200.1060.0
Z-Buffer depth: 24 bits
Total Video Memory: 2 GB
C:\Program Files\Rhino 7\Plug-ins\Karamba\License\Karamba3D_LicensePlugin_Rhino7.rhp “Karamba3DLicense”
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.16.22067.13001
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.16.22067.13001
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.16.22067.13001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.16.22067.13001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.16.22067.13001
Alas, you are attempting to use Windows Rhino7 on a Mac via Parallels. This is not supported by McNeel. Earlier versions of Rhino (V5 and earlier) usually worked fairly well despite no McNeel support but V7 not so much. The culprit is Parallels’ inadequate OpenGL support of Nvidia/AMD cards in the Mac.
I believe that your V7 license allows you to download the Mac version of Rhino and use it as long as you are not using the windows version on a windows machine at the same time. I believe your Cloud Zoo will manage that for you. (I run a standalone version so for me this is just hearsay from the forum.)
Hi Wim, thanks for your comment. Just re-opened the Rhino file that was imported via the PC / Parallels on my Mac Rhino 7 and there it shows
Great stuff - this helps a lot ! J
