opening e57 file works fine
however
- the whole surface doesn’t display. only when scaled or other command will it display whole 4 gig e57 file
- when i save file, it grows to 9 gigs. ok fine. However when i try to open the 3dm file which is a e57 file saved as 3dm, it says it has a ‘unreadable geometry object’ and i allow it to continue but once file opened, NO remnants of the e57 file?
any others have this issue? how best to save/convert an e57 file opened with Rhino 7 so can be reopened??
Thank you for any ideas
